M Gas Tank ?
John Moore
01-17-2007 13:11:35
Saw a gas tank (same measurements as the one on my M) with what appears as a factory vent with the line running down the tank top and front where it is secured to the front bracket. As my M does not have the vent, I'm wondering if that is a M tank. Any help appreciated. John
John Moore
01-18-2007 18:40:55
 Re: M Gas Tank ? in reply to John Moore, 01-17-2007 13:11:35
Thanks for the help everyone. It is a sound tank. Think I'll get it and close-up the vent. John
tstex2
01-17-2007 15:35:58
John/Wayne,
I am not sure if you are wanting to use this gas tank for your M? If so, Wayne, would the hood fit over the spout/upper neck of a 420/430 gas tank? I know there are some quirks with the grille's on M & MT working, so maybe there would be an issue with different hoods. Just curious.
regards,
tstex
Wayne in Tn.
01-17-2007 18:14:16
 Re: M Gas Tank ? in reply to tstex2, 01-17-2007 15:35:58
That is what I meant to say when mentioning the (filler tube) I meant the spout or neck where you put the gas in. If it is in the same location as the M, then the hood should work.
I have used those tanks with the vent, on a 40 and the hood fit fine. Of course the 40 did not come with the vent on top.
Wayne in Tn.
01-17-2007 14:33:59
John, what you have is a tank off a 420 or 430. I am not sure if it will work on an M or not. If the filler tube is in the same location it should. You might have to bend the hydraulic lines around that vent.
