Getting rings in the block
36 A
01-30-2007 16:54:54
How do you go about getting the rings in the block on a us A block with that ridge.Ring compresser work ? help
430WLPG
01-30-2007 17:47:05
 Re: Getting rings in the block in reply to 36 A, 01-30-2007 16:54:54
I always pull the block a put them in from the back side and then put the whole thing in as a assembly
Rusty Junk TX
01-31-2007 19:28:51
 Re: Getting rings in the block in reply to 430WLPG, 01-30-2007 17:47:05
The 1st JD tractor I learned on had a power block and that was the ONLY way. That is the way I have done it every since, power block or not. I put them in "loaded".
Marcus
Mike M
02-01-2007 07:25:19
 Re: Getting rings in the block in reply to Rusty Junk TX, 01-31-2007 19:28:51
That's fine if you have everything apart and all the sheetmetal off. But these tractors were made to pull the head and block for service of normal wear and tear without tearing too much apart.
Drew
02-01-2007 10:02:03
 Re: Getting rings in the block in reply to Mike M, 02-01-2007 07:25:19
Since when do you have to take the sheetmetal off to get the block out?
Mike M
02-01-2007 10:12:26
 Re: Getting rings in the block in reply to Drew, 02-01-2007 10:02:03
The guys that are pulling them with the pistons and rods all in are going to have to. Ain't no way your going to pull the block in a pressed frame A or B and leave the pistons and rods in without tearing alot of other stuff out of the way.
Mike M
01-30-2007 17:17:21
If it is like the unstyled B the cyl. is stepped you just squeeze them by hand and start them in and then the tapered ramp inside will guide them in. I just bump it in with a rubber hammer.
36 A
01-30-2007 19:29:59
 Re: Getting rings in the block in reply to Mike M, 01-30-2007 17:17:21
thanks i was woundering if that would work.
Mike M
01-31-2007 05:02:58
 Re: Getting rings in the block in reply to 36 A, 01-30-2007 19:29:59
They were designed that way on purpose so you could easily work on them with little tools. Something long ago forgotten in todays machines.
