Front rim on unstyled 37 A
37 JD A
01-31-2007 08:16:35
Is there a stamped number somewhere on this rim? I don't see one, but maybe I'm looking in the wrong place. I sure would like some info. on where to locate one to match the original one I have. The mounting bolt holes must be 2 inches in from back edge of rim. Someone out there must have had this same problem. Thanks-
Duane Larson
01-31-2007 10:39:20
 Re: Front rim on unstyled 37 A in reply to 37 JD A, 01-31-2007 08:16:35
37 JD A,
Your front wheels are JD1232, probably version 1, which attaches the wheel center to the rim with 10 uniformly spaced rivets. The rim is 4.00Ex16, and the wheel is non-reversible. The part number is not stamped on your wheels, but if you check with dealers in Green Magazine or Two Cylinder they will know the wheel you are asking about. Version 2 of the wheel is attached with a total of 8 rivets, with the wheel center having four scallops where 2 rivets/scallop are used to attach the wheel center to the rim. Version 3 has 4 hand holes in addition to the Version 2 description.
You might check with Harlan Wilson, Wilson Tire, in Ohio, 740-625-6894 as he often has wheels for sale, or can find one.
Deere Heaven
01-31-2007 09:02:35
I dont think they had #'s on them I can check tonight. Do you have pictures of yours, that would help. Thanks, Brian
37JD A
01-31-2007 09:32:10
 Re: Front rim on unstyled 37 A in reply to Deere Heaven , 01-31-2007 09:02:35
I don't have pictures of my rims at my desk right now. The inside plate is riveted all the way around on the inside. The bolt holes are about 2 inches from the back of the rim and about 4 inches from the front side of the rim.
