MW Oil Pan, Filter Insert Question, JD 4010
4010 Pride
02-01-2007 06:54:52
Mornin", I very luckily came by and purchased an M&W oil pan for my 4010, but it doesn"t have the oil filter insert. What should I do in this scenario? The 4 studs are still on the pan where the insert mounts, but the M&W insert is not there. Will insert off of my original JD pan work? Thanks so much for any help!
Jon in NY
4010 Pride
02-01-2007 11:05:48
 Re: MW Oil Pan, Filter Insert Question, JD 4010 in reply to 4010 Pride, 02-01-2007 06:54:52
Link
According to this link which shows the oil filter and pump break-down, the insert should bolt right up to the M&W pan. For some reason, I could be wrong, but I thought that maybe the pan came with the insert from m&w. But I think I am wrong. Thanks for your information WTW! Jon in NY
WTW
02-01-2007 08:33:48
If the hole in the side of the M&W pan is there for the oil filter, filter "can" will fit off your original cast iron pan. If your M&W pan does not have the hole for the filter can then you have an issue. If that is the case let me know as I would trade my M&W pan with filter can hole for yours without. DW
4010 Pride
02-01-2007 10:36:35
 Re: MW Oil Pan, Filter Insert Question, JD 4010 in reply to WTW, 02-01-2007 08:33:48
Hi, yes the hole for the filter insert is in the side of the pan. The studs are there to tighten the insert to the pan. But I don"t understand how the oil filtration "flow" will work. My tractor is tucked away in my cousin"s barn until May for tillage and planting sweet corn. Thanks. Jon in NY
WTW
02-01-2007 12:50:16
 Re: MW Oil Pan, Filter Insert Question, JD 4010 in reply to 4010 Pride, 02-01-2007 10:36:35
Jon The filter can seals over a o-ringed flange on engine oil pump body. Filter sets on pump supply port. Oil pump pumps oil into the center of filter. Oil passes through paper filter and returns back into the base of oil pump where it is directed/routed to the main oil gallery in block. Hope this answers your question, DW
4010 Pride
02-01-2007 14:55:32
 Re: MW Oil Pan, Filter Insert Question, JD 4010 in reply to WTW, 02-01-2007 12:50:16
DW, thanks a million, you answered my question perfectly!
Jon in NY
