Fan shaft bearing
36 A
02-07-2007 19:21:18
On my 36 A the fan bearing has spun on the shaft.Is this a problem on this style fan or not.Talked to some and they said to put in sealed bearing has anyone ever done this .
Mike M
02-08-2007 04:38:46
 Re: Fan shaft bearing in reply to 36 A, 02-07-2007 19:21:18
If it has spun on the shaft then I would assume the shaft is worn down and will require some reconditioning too. Those original style parts are still available so I would put back in what is suspose to be in there. Afterall they lasted 71 years,not bad by any standards.
CalJim
02-07-2007 21:35:57
Just finished rebuilding fan shaft on a 36 B.
Bearings,felts,etc. were all available thru
Deere or NewTech, can't recall which.
Don't know about a sealed bearing, sounds like
a good idea though.
I did install a 90 degree grease zerk instead
of pipe plug on top of housing. CalJim
