JD301A Hydraulic pump failure..Clean out filter?
Joe Phillips
02-26-2007 14:43:40
The hydraulic pump failed on my JD301A and pretty much self destructed. What should I do to clean out the system and would you recommend a clean out filter if they even make one for this machine.My friend said it is a filter with super small microns that will catch metal,etc.
johns48jdb
02-26-2007 15:28:12
 Re: JD301A Hydraulic pump failure..Clean out filte in reply to Joe Phillips, 02-26-2007 14:43:40
sorry for this post since i have no idea what kind of tractor this is , but my first thought was i wonder if there is any where to put a magnet into the system to help catch some of the metal pieces. also i would put in some kerosene and a filter, run the tractor for a few minutes and then drain the fluid out and change the filter. i might even consider doing this twice depending on what the fluid looked like the first time you drain it out. if you work it much i know i would consider changing it again after a couple of hours running time. sounds expensive, but another new pump sounds even worse. what happened to the old pump? i used some fluid in my ih tractor once and it ate the linings off the clutch pack for the pto drive. it was valvoline trany fluid. i was told not to use it and did any way. (hay on the ground and no other fluid available) good luck
rrlund
02-27-2007 08:43:34
 Re: JD301A Hydraulic pump failure..Clean out filte in reply to johns48jdb, 02-26-2007 15:28:12
Isn't the 301 the same as a 1020? In which case there is a plug on the side at the bottom of the rearend housing that comes out using a 1/2 inch drive breaker bar. That is a long plastic framed if you will,metal screen. I wouldn't say that it is REAL fine,but quite and will filter out quite a lot. If that plug will come out,I'd sure pull it out of there and clean it.
