1020 rack pinion wheel
Ward M. Parker
01-03-2000 08:48:38
The pinion is broken-missing. How can I move the wheel in a few inches? She is set too wide for my uses. Thanks, Ward
CLOONEY
01-03-2000 14:58:16
 Re: 1020 rack pinion wheel in reply to Ward M. Parker, 01-03-2000 08:48:38
Ward,Loosen the 3 clamp bolts then turn the clamp release bolts in to loosen clamp, then jack up tractor about 1" then place both feet hard against bottom of tire (pushing tire towards tractor) then pound on top of tire (toward tractor) with your hands or a big hammer. By keeping pressure on bottom & hitting top it should move in. If it's really stuck drive tractor on side hill with loosened wheel on the down side, that should move it in. Drive slowly when it moves it will move in fast.
