diesel engines
123 farmer
03-05-2007 05:44:26
How bad is it to run a diesel with a blown head gasket and does starting fluid hurt the engines? thanks
Glen in TX
03-05-2007 06:44:13
 Re: diesel engines in reply to 123 farmer, 03-05-2007 05:44:26
Too much starting fluid? You'll finish the engine off and be overhauling it sooner to replace busted rings and burnt pistons is all.
jdemaris
03-05-2007 06:04:28
With the head gasket, it depends where and how it's blown. Coolant in the engine oil and/or combustion chamber can ruin an engine pretty quick. But a leak that sends coolant out the exhaust, or out to the air - won't cause immediate damage and if you don't let the engine overheat.
In regard to ether - it depends how you use it, and how much you use, and on the design of the engine. With some engines - you can easily ruin them fast. Deere diesels with square-cut rings - instead of Keystone are a good example - e.g. as used in 350 crawlers, 1020 ag. tractors, early 450 crawlers, etc. Those top rings and pistons shatter pretty easy when hit with a lot of ether. When Deere puts factory installed ether injection on an engine - manual or electric- a control orifice is used to prevent how much ether you can jam in at one time. But, when spraying directly into an intake or air-cleaner, there is no control. In our shop - we did more engine repair work from cold-weather ether starting - then from normal wear. Farm tractors were rarely a problem since they usually had block heaters. Big problem was with crawlers and log skidders sitting in the woods a 20 below zero.
123 farmer
03-05-2007 08:16:16
 Re: diesel engines in reply to jdemaris, 03-05-2007 06:04:28
sends a little cooland out to run along outside of block on one side. and on the other it looks like a little oil is leakin down side of block starting between block and head
buickanddeere
03-05-2007 05:57:56
Bad. If too much is used or if the engine has a manifold heater or glow plugs, yes.
