JD hydraulic pump
37 chief
03-10-2007 16:25:04
My JD 401b industrial hydraulic pump is making some sounds I know are not right. When I raise the lift arms the noise goes away some, then returns. I changed the filter and cleaned the screen, and did not see one speck of metal. I purchased this tractor not running, so I don't know the history of the pump. Can a kit be purchased for these pumps? I believe this tractor has the same pump as the 2440 farm tractor. Thanks for any help. Stan
Shoes
03-12-2007 17:23:26
 Re: JD hydraulic pump in reply to 37 chief, 03-10-2007 16:25:04
I am not familiar with this model tractor, or which style pump it uses, but I have experienced this noise before on a 4010 and also a 1020. Under the troubleshooting section in the technical manual, they suggest that there is air trapped in the stroke control housing. On both the 4010 and 1020 that I mentioned, I was able to get rid of the noise by loosening the plug opposite the stroke control adjusting screw while tractor is running, to release the trapped air.
MyrlfromPA
03-12-2007 05:37:47
It may just be that the canister (can not remember right name for it) in the hydraulic system need recharged. Do you feel a vibration in the control handle? The canister I am talking about is to keep them rotary ppiston pumps at an even pressure so they dont rattle.
Roy Suomi
03-11-2007 14:16:40
The rattling noise you hear are from the pump coupler on the splines if everything else is tight..Just a common noise on these machines..I wouldn't loose any sleep on this problem..Eventually the pump will quit turning because the splines on the cast coupler have stripped out..Most times the splines on the pump shaft are ok..Nothing is going to go through the radiator..When you replace the coupler , neverseize the heck out of it on the splines....
MSM
03-11-2007 08:13:59
Possibly the stroke control valve in the pump is bypassing slightly,or you have a slight internal leak in the hydraulic system that is causing the hydraulic pump to stroke(pump) slightly to make up for the leak which causes the chatter noise you are hearing
buickanddeere
03-10-2007 17:31:21
What condition is the coupler in?
37 chief
03-10-2007 21:40:46
 Re: JD hydraulic pump in reply to buickanddeere, 03-10-2007 17:31:21
The coupler has new rubber bushings,and a good coupler clamp just installed. When I got the tractor the bushings were shot, wearing into the clamp. Stan
buickanddeere
03-11-2007 04:49:03
 Re: JD hydraulic pump in reply to 37 chief, 03-10-2007 21:40:46
Could be either the pump of the front of the engine when the coupler was so messed up. What condition is the balancer in?
37 chief
03-11-2007 08:09:20
 Re: JD hydraulic pump in reply to buickanddeere, 03-11-2007 04:49:03
Everything else looks to be in good condition. Stan
