S/N tag cleaning
Jeremy W
03-11-2007 20:41:01
I have a JD B with a cast iron frame and I am trying to figure out what year it is. I found the S/N tag, but it is rusted and I can't read it, other than where is says John Deere.
Does anyone know what I can do to clean it up so that I can read it without destroying it in the process?
Sam in MN.
03-12-2007 10:20:19
 Re: S/N tag cleaning in reply to Jeremy W, 03-11-2007 20:41:01
I have had great success using pure Acetone, which is the primary ingredient of Nail Polish Remover. Soak for a couple minutes and work around with a Q-Tip. Wipe off and repeat this process. If any numbers still exist, they will show using this method.
Any type of abrasive action will damage or destroy the numbers
Jim Broughton
03-11-2007 21:26:13
Jeremy; Take a small piece of 4-0 or 3-0 steel wool and lightly rub the tag, just so it's clean. Tape a small piece of paper over the plate and rub with a soft lead pencil or charcoal stick. It should give you the numbers so you can find your answers !
Good luck ! Jim B.
Scott's B haven
03-12-2007 16:45:20
 Re: S/N tag cleaning in reply to Jim Broughton, 03-11-2007 21:26:13
I tried it all and had no luck the numbers where gone.So I popped off the tag and took it out in the sun light and it could be seen from the back side. good luck
