JD clutch noise
37 chief
03-13-2007 19:52:20
Here is a new one on me. I replaced the T/O bearing on my JD 401b industrial (Same as the 2440 farm tractor) When I push down the clutch I get a noise like a bad T/O bearing. The noise goes away when I release the clutch. Any ideas. This is what I get when I buy a tractor not running. The motor sounds real good after a complete rebuild. The other problem is a noisy hyd. pump. Thanks for any input. Stan
msb
03-14-2007 08:37:46
 Re: JD clutch noise in reply to 37 chief, 03-13-2007 19:52:20
Pilot bearing replaced? Fiber thrust washer behind the pilot bearing left out?
Drew
03-13-2007 20:40:48
Is there a pilot bearing in the flywheel that supports the front of the input shaft? If so, when you release the clutch, the flywheel and input shaft are spinning as one unit, but when the clutch is depressed, the flywheel is spinning and the input shaft isnt and that bearing would be spinning. Just an idea....
37 chief
03-13-2007 21:34:31
 Re: JD clutch noise in reply to Drew, 03-13-2007 20:40:48
There is a bearing in flywheel, and it is new. Stan
