Help JD B serial number
Jim
01-04-2000 12:05:02
I am trying to read the serial number on a JD B but plate is rusty and not legible. I tried some WD-40 and light sanding with steel wool and emery cloth. That helped but still can't read. I don't want to do something that will ruin it. Any suggestions would be greatly appreciated.
tim thompson
01-16-2000 03:37:13
 Re: Help JD B serial number in reply to Jim, 01-04-2000 12:05:02
lay a piece of paper over the serial no. & using the side of a pencil lead go over the serial no. with just enough pressure to darken the paper.
if the numbers are raised they will turn out darker,if they are stamped they will be lighter .
zane
01-05-2000 15:34:57
Clean the plate well with water, detergent, and a soft brush. Let it dry and then spray paint it white. Wipe the plate with a coarse cloth while the paint is still wet. If you're lucky, there'll be a little paint left in the recesses of the stamped numbers.
Mark
01-04-2000 13:31:13
You might remove the rivets and take the plate off and look at the backside of the plate and rub some chalk on the numbers and figure it out that way. The numbers are stamped onto the plate and might be legible that way
