finding carburetor numbers on 3010 and.....
joevet
03-29-2007 11:34:55
I"m needing to rebuild the carb on my 3010 and need to know the make and model numbers of the carb. It no longer has the tag. Any ideas or photos to help me out? Also, if anyone can recommend a useful guide for completing the task, I"d appreciate the referral. Thanks.
Glen in TX
03-29-2007 13:06:42
 Re: finding carburetor numbers on 3010 and..... in reply to joevet, 03-29-2007 11:34:55
Could be at least 5 or 6 different ones according to MS, Marvel Schebler 1-400 carb catalog.
MS# USX-21, JD# AR28635R,
MS# USX-31, JD# AR32639R,
MS# USX-36, JD# AR39702,
MS# USX-49SL, JD# AR45161
All MS carbs above use Zenith # K7518 Kit.
Zenith replacement carburetor for all above on 3010 was 14990 using kit # K2137. The 3020 should have had Zenith carb 12879 (JD# ar46798) using kit # K2137 also.
Bob
03-29-2007 11:42:06
Go to JDPARTS and look it up. You can do that WITHOUT registering; (but won't be able to see the prices).
If the carb is original or a DEERE replacement it will be obvious which one you have from the drawings; and you can then look up the part numbers.
On the odd chance someone has stuck an "odd" carb on there; It gets a lttle tougher!
