Best Place to have a Duplex Dual-Induction Carb Do
Jen Jensen
04-04-2007 04:01:39
Where is the best place to send a carburetor out to? We have a couple of carb's off a JD 520 that need to be sent out to a "professional". Any ideas?? Appreciate your input. Thanks.
Napi
04-04-2007 13:35:13
 Re: Best Place to have a Duplex Dual-Induction Car in reply to Jen Jensen, 04-04-2007 04:01:39
This guy did a good job for me.
Duane Larson
04-04-2007 09:12:05
Jen,
Something else Jeff may try if he hasn't - this provides a handy access to intermediate locations in the idle circuits. And the ball bearings blocking the drill passages are too hard to drill - I use a wire welder to build up a tab to the ball and pull the tab with a slide hammer - may take a couple of tries.-----
It sounds like some of the idle passages are still plugged. On a duplex carb like yours, it sometimes helps to check the idle circuit if you pull the two 7/16" freeze plugs located just above the bowl (one is below the fuel inlet and the second is 180 deg from the first). The exposed holes are an intermediate step for the idle fuel passages and you will see an entrance and exit passage behind the freeze plug. On each side squirt some carb cleaner in each passage and see where it comes out. Some should come out the small idle holes near the throttle plates. Squirt some cleaner down the small hole next to the nozzle plug and it should come out behind the freeze plug. This will indicate any blocked passages. If they are blocked you will have to remove the small, hard stainless steel balls to be able to ream the passages. This is not easy as they are too hard to drill. Check the archives for ways to remove them. Replacement freeze plugs are available (www.robertscarbrepair.com), but you may be able to reuse the old ones. I center-drill the plug with a #21 drill (being very careful not to let the drill go in too far and mess something up) and tap 10-32, put in a screw and pull the plug with a slide hammer. This removes the plug with little damage except for the hole. Plug the freeze plug hole with JBweld, put some sealer on the edges of the freeze plug, and tap back in with a punch around the edges.
Jen Jensen
04-04-2007 10:11:43
 Re: Best Place to have a Duplex Dual-Induction Car in reply to Duane Larson, 04-04-2007 09:12:05
Duane,
I THANK YOU SO MUCH FOR YOUR HELP!!!!! You certainly know your stuff! I have saved this info & printed it off for Jeff. Will let you know how we make out. Appreciate it so much. I am so glad there are such good people in this hobby/business! Thanks.
machinery-man
04-04-2007 08:02:10
Jen: why don"t you take a crack at it yourself...the main thing is cleaning the ports good..on the duplex removing the ball bearings your self is difficult...but you can clean ports with small stiff wire, change seat and needle as gaskets without much difficulty. Also you want to relevel the base of the metal bowl...I always take a hammer end on smooth surface...if this is too much JD makes a carb guide and Roberts has all the necessary parts...shaking these carbs around will mess up the float and needle...they are getting to expensive to ship...take extra/extra care in boxing for shipping. Most of these duplexs will sell for $300+ ....
Jen Jensen
04-04-2007 08:18:28
 Re: Best Place to have a Duplex Dual-Induction Car in reply to machinery-man, 04-04-2007 08:02:10
Yes, we have tried ourselves. Jeff has been a mechanic over 30 years now. We have one on a 520 now that he has worked on off & on. Just can't seem to get it cleared with wire, and the balls need drilling out. Not brave enough for that. Don't want to ruin the carburetor. We usually can "get by". Have access to all the parts ourselves. It is just when we can't correct them, we need professional help. I miss Doug Burrey. I would like to find someone like that, that you can rely on. That when it is done, it is done. Doug did a 620 carb for us. We got it back, put it on the tractor, and didn't even have to adjust it at all! We have a good carburetor guy about 80 miles from here, but it takes too much time to get it back. All replies appreciated--THANKS SO MUCH.
Bobl1958
04-04-2007 07:37:48
Jen - I have sent many carbs to Burrey's. I had a great respect for Doug, but I think someone else is running the business now and don't know for sure, but I would think they would do a good job. Lately I have a local carb shop that rebuilds mine and he does a good job, but I know there are others out there doing it for a living that might do better. Bob
Jen Jensen
04-04-2007 07:45:01
 Re: Best Place to have a Duplex Dual-Induction Car in reply to Bobl1958, 04-04-2007 07:37:48
Yes, I had great respect for Doug as well. Wish he was still doing them. Yes, the business was bought out. Thanks.
F-I-T
04-04-2007 07:18:04
The only personal experience I can attest to is Robert's Carburetor. Long lead times, but great results, at least in my case.
Frank
G/MAN
04-05-2007 07:30:27
 Re: Best Place to have a Duplex Dual-Induction Car in reply to F-I-T, 04-04-2007 07:18:04
The secret is to have it sent in by a dealership. Much faster turn around when there's a John Deere dealer name on the shipping label - days, not weeks or months.
Jen Jensen
04-04-2007 07:29:56
Thank you for your input. I am glad you had a good experience with them. We worked on a customer's tractor that Robert's had rebuilt the carb. The tractor skipped terrible. We took the carb off and made some adjustments, put it back on, and the tractor ran decent. Robert's blamed it on shipping--jiggling the carb around in the box. We are in hopes of finding someone else other than Robert's or Burrey's. Appreciate hearing about your experience.
Jen Jensen
04-05-2007 05:42:33
 Re: Best Place to have a Duplex Dual-Induction Car in reply to Jen Jensen, 04-04-2007 07:29:56
Thank you all for your responses. McDonald Carb looks like a very good source. Will try them out.
Appreciate it-Jennifer
G/MAN
04-04-2007 13:31:06
I don't think incorrect adjustments should be a surprise, coming from anybody that builds carbs. I know that Robert test-runs his carbs, but in no way is that a guarantee that it's going to run correctly on the tractor it ends up on - every engine/tractor is different. His test-run process is likely to see that the various circuits are free and clear, the mixture screws work properly and that the carburetor doesn't leak. I've gone through some carbs myself (minor stuff like new gaskets and thel like - I've never gone throug all the passages and so forth) and we've (the Deere dealership I work for) have sent a few to Robert's, and either way you're going to have to go to go through the entire adjustment process when you reinstall the carb, at least if you want it to run correctly. The old John Deere service manuals will tell you that - initial adjustmens are only starting points.
