Wheels weights and hitch part
1954 JD 50
04-06-2007 09:28:06
I was cleaning up in the shed and found a couple John Deere parts that I am trying to figure out what they fit. I tried JDParts.com but get the error message "Invalid part" when I enter the part numbers.
The part numbers are: wheel weights D2628R and hitch part H-11400-H.
Can someone please help me with what tractors they are for?
Can someone also provide some input into what I am doing wrong on the JDParts site? (No smart aleck comments please)
Green Greener
04-07-2007 04:13:43
 Re: Wheels weights and hitch part in reply to 1954 JD 50, 04-06-2007 09:28:06
I just pulled these same weights off from a 1948 A and a 1948 B with Cast Wheels. About 140 lbs. each. Here's some listed on eBay until 4-7-07 afternoon.
Glen in TX
04-06-2007 18:25:03
third party image
Too old to be listed in JD parts online. D2628R is a JD rear wheel weight that fit many letter series 2 cyld. JD tractors. You might also find it without the JD number on it as a local made copy foundry weight. I'm not sure if it will fit some of the later series ones or not so just measure mounting holes to find out. Go to "Parts & Pieces" photo gallery in left column and enter my handle and find more pics of these type weights and also F&H DP2628 weights. They will stack together using the JD D2628R as a starter weight on inside on cast center on Ds and ARs and then stack on some of the F&H weights. The F&H weight is too large diameter to use as first starter weight on Ds & ARs without having to grind off some on outside diameter. That same F&H weight was used on many other brand tractors too.
I don't know what your other number is and it didn't work for me at JD parts either even leaving the H off the end. Doesn't show up in H tractors parts book either. Might be a combine part? Harvester? Someone with JD master parts index can tell what you it is or maybe your dealer can.
MikeinKy
04-06-2007 10:17:15
D2628R fits 40,420,430,2010
H11400H fits mowers, 8,8W, 9W,37,38,39
Hope this helps
1954 JD 50
04-06-2007 13:10:37
 Re: Wheels weights and hitch part in reply to MikeinKy, 04-06-2007 10:17:15
Is it possible the wheel weights would fit a 50 also since you listed a 40 as one of the models? Or a 2510?
SMASH
04-06-2007 09:55:08
It has been a while since I used JDParts.com, So I could be wrong. But, I think if you inter a part # that they don"t sell any longer it comes up "Invalid part." Your part #"s are probably good # you just can"t buy them from JD any more. I think if they have changed the part # it shows you the replacement #.
johns48jdb
04-06-2007 09:45:29
i've seen comments here about leaving the r off of the part number to make it come up. never used the site so i don't know. might give it a try and leave off the h too
