help with model number
Jim in OK
04-10-2007 18:14:09
third party image
I hope the pic makes it here. Can anyone tell me the model number of this lister planter and time frame they where made? thanks
Maark
04-12-2007 10:44:57
 Re: help with model number in reply to Jim in OK, 04-10-2007 18:14:09
I mounted mine last summer but didn't have the correct rockshaft arms. So I made some out of cultivator lift arms, I have since found the correct arms but didn't have the length for the u-shaped links. It is quite a show piece mounted on a tractor. The drawbar needs to be removed as does the pto shield to attach to a tractor. Thanks again for your info.
Maark
04-11-2007 08:32:31
Do you have the lift arms that go on the powerlift rockshaft? I need the correct length of the lift rods that go from the arms to the planter frame. Thanks...
Jim in OK
04-11-2007 18:33:23
 Re: help with model number in reply to Maark, 04-11-2007 08:32:31
Maark the rod piece is about 10" from inside of bend to other inside bend. I have more lift arms but only the one rod with the 'U' shape bends
Maark
04-11-2007 08:29:28
Looks like an A-140.Mid to late 30's. I have one on a 36A.
