John Deere 4455 light problems
joeman
04-11-2007 19:04:00
I have purchased my first John Deere. I have always wanted a 4455 MFD/powershift. Well I finally found one. It is a 1991 with 4000 hours. My problem is that the front three lights and the front fender lights do not work. When I looked at it they did. I have checked the fuse which was told it was F11 fuse. It was good. I checked the three front lights for their connection. They were connected. I have all four back lights. I was told that the fronts and fronts on fenders are connected.
Thank you in advance.
G/MAN
04-12-2007 13:35:40
 Re: John Deere 4455 light problems in reply to joeman, 04-11-2007 19:04:00
It could be anything from faulty relays to bad connections at any number of connectors to a problem at the power distribution board to ???. You need a service manual with the wiring schematics and troubleshooting info. The newer tractors like the 50s, 55s and 60s are much less prone to the light switch plug melting situation that was mentioned - I've never seen one do that. And usually that's caused by overloading light circuits in the older tractors by adding extra lights and not using an auxiliar switch and breakers.
Tx Jim
04-12-2007 04:33:38
Joe,the dimmer switch also controls some of the work lights. There are relays that provide electricity also. Tx Jim
joeman
04-11-2007 19:34:32
Thank you and I will try that tomorrow
Craig Arnold
04-11-2007 19:17:48
Check your light switch. It should have a big connector on the back that goes to the wiring harness. Over a period of time doing field work the contacts can heat up and melt causing them to make bad connection and work one time and not the next. Try wiggling this and see if it helps. Had a 4430 that did this and we finally had to replace the switch and connector plug to fix. I put alum. foil on contact prongs for a temporary fix while working it. I would loose front lights but still have back lights.
