jdemaris, That looks just like the pump I have. The Tag on the pump shows it to be a CDC model. CDC331-8DQ? The last digit is about illegible. The access door on the front-timing cover is what I must have been missing so far. I need to drain the radiator and remove the lower radiator hose for better access & view. >>I used to keep a bag of gear-sets in my tool box for road calls. Today ?? Most parts became obsolete for the C pumps back in the early 80s. Deere was selling changeover kits to update tractors - e.g. your 150 diesel - to the later pumps<< Do you think I can locate a rack & pinion set? Maybe you got a set left over in that bag of yours! Do you think I just need to jam the old rack out, clean up the tube a bit and install another set? I don't think cleaning up the old rack is a good option. Though I guess I won’t know till I get it out. Do you know if the tube attached to the pump (in your last pic) can be removed without removing the pump? I'm not sure if I need to remove it, but the rack is pretty well frozen in there. I really appreciate the info! Thanks, Jim
