2155 high-rev miss
jimtNV
05-02-2007 21:02:36
what would cause a high rev. engine miss in one or more of the cylinders in a 2155 with 5200 hrs? All filters have been replaced and the fuel lines blowed out.
jdemaris
05-03-2007 05:45:31
 Re: 2155 high-rev miss in reply to jimtNV, 05-02-2007 21:02:36
Depends what kind of miss. If the tractor still has good power under load, but misses at high RPMs no-load, the timing is not advancing correctly. If so, it's pretty easy to adjust.
buickanddeere
05-03-2007 04:57:17
Valve lash? How long since the injectors were serviced. Is the miss at max rpm no load or max rated rpm and fully loaded?
720 in pa
05-03-2007 04:05:54
check your transfer pump.i would replace it and see what happens.sounds like the enggine is probably starved for fuel at high rpms.
720 in pa
05-03-2007 04:09:25
 Re: 2155 high-rev miss in reply to 720 in pa, 05-03-2007 04:05:54
sorry didnt finish before i posted.you might want to check the screen in the back of the injection pump.remove the fuel supply line andunscrew fitting in pump.there is a screen in there
