1935 JD A oil pump gears needed
4020
05-07-2007 14:13:36
I am working on an early A that has the oil pump up on the side of the main case under the crankshaft, flywheel side. Mine are so worn out they are just about to lock up. So, I would like to purchase two new gears. Is that possible? If not, what is the best way to fix this problem? Thanks, David
Maark
05-07-2007 14:28:20
 Re: 1935 JD A oil pump gears needed in reply to 4020, 05-07-2007 14:13:36
www.detwilertractor.com They list new reproduction gears for $95.00
4020
05-07-2007 16:33:08
 Re: 1935 JD A oil pump gears needed in reply to Maark, 05-07-2007 14:28:20
Thanks for the help. I have the Detwiler catalog but did not think to use it.
