4020 won't go into 6th gear
jelsas26
05-15-2007 06:21:46
Can anyone tell me why it won't go into 6th? All other gears work fine. Is there a problem with using the tractor until I can get it fixed? I need to get my hay in and I only have this one tractor. Thanks. Oh, any ideas what the repair cost would be?
dwag
05-15-2007 17:54:59
 Re: 4020 won't go into 6th gear in reply to jelsas26, 05-15-2007 06:21:46
Sounds like a linkage problem. 6th is the "low side" of 4th gear, 8th the high side. If "low side" works in other ranges, syncro\trans shaft is OK.
G/MAN
05-15-2007 07:28:08
Isolate the problem to either the shifter or the transmission. Unhook the shift rods at the levers on the outside of the transmission and see if you can move them through their full range of travel. Repair cost is going to depend on labor rate, the person doing the work, what actually is wrong and parts costs.
