730 LP pistons
2cylinderlp
05-28-2007 19:23:31
third party image
My 730LP had pitting in the bores from sitting too long. So the block had to be bored. But oversize LP pistons were impossible to find. A high compression gasoline piston is available. It has a perfectly flat top. I bought a pair of the high compression gasoline pistons in the proper oversize and had their tops built up to match the profile of the original John Deere pistons. The result appears to be quite acceptable. And I didn"t have to compromise the block with boring and sleeving, and then still have to use my old pistons. The work of modifying the pistons was done by machinists at Detwiler Tractor Parts, and I can recommend them for having done an excellent job. The pistons along with excellent advice came from Hinrich"s.
bigblock
05-29-2007 15:13:15
 Re: 730 LP pistons in reply to 2cylinderlp, 05-28-2007 19:23:31
2cyl,where did you buy those pistons?
2cylindelp
05-29-2007 15:43:51
 Re: 730 LP pistons in reply to bigblock, 05-29-2007 15:13:15
Jerry Hinrichs call 815-778-1900
buickanddeere
05-29-2007 11:07:12
That's all well and good. However I would also consider just getting the pistons made to your specs in the 1st place rather than welding up a new piston.
Link
2cylinderlp
05-29-2007 15:49:17
 Re: 730 LP pistons in reply to buickanddeere, 05-29-2007 11:07:12
I appreciate the suggestion and I think if I get into this situation again I would consider that option. I have another couple tractors to go before I will have met my goal for restorations and they are both LPs.
Mike M
05-29-2007 05:50:00
Looks good ! Did they balance them to the same weight ?
F-I-T
05-29-2007 06:22:04
 Re: 730 LP pistons in reply to Mike M, 05-29-2007 05:50:00
Not only should they weigh the same, but they should be paired by "moment weight". That's how we paired up sets of 2 or 3 jet engine fan blades at a time. Once paired, you could safely replace an opposing pair or 120* triad blades in the field and not affect the original engine balance.
Moment weighing consists of balancing the pistons on a beam, then getting the beam level when the pistons are sticking out from the center, from a common distance from center point. You would generally locate them in the position that they would be running. The everyday explanation is that you have a 2 pound baseball bat, and a two pound wooden cylinder of the same diameter. They would weigh the same on a balance scale, but it you mounted them butt end toward the center, far end pointing out, the cylinder would not have a tapered handle, nor would it be as long, so more of its mass is closer to the butt end, but the bat has a center of gravity that is farther out, so the scale would say the bat is "heavier per inch from the fulcrum", or over that moment.
So they might weigh the same, but in motion, the bat takes more force to swing. In an assembly of a rod and a piston, it can make a considerable difference, of course not as nmuch in a 1200 rpm engine, but every bit helps. Using a static balancing method like this can virtually replace a dynamic method that most shops don't possess. But anyway, if you feel the need to balance, static gross weight is a good place to start, but if you can moment weigh them, you'll get them so close that the engine will not be able to sense any difference.
Just think about what happens if you moment weigh a 2 pound, 6' long broom stick versus the basball bat? I helped a local youngster build a unit and he won his local science fair a couple of years ago. It's a cute trick, especially when you start sticking things on two identical objects so that you can see how little it takes to throw things off.
Frank
