JD 140 -30000 electric clutch
Jim Stouffer
06-03-2007 08:08:33
First one thing then another! I will be looking for an electric clutch for my early 140 ser# 4446m (1968) Are the electric clutches for the later 30,000+ models the same? When it comes to this tractor I am as dumb as a rock. What exactly does the 'patio' distinction mean? Is it more in demand than the other models?
Jim
Bob
06-03-2007 09:52:42
 Re: JD 140 -30000 electric clutch in reply to Jim Stouffer, 06-03-2007 08:08:33
The various electric clutches used on the 140's through the years are interchangeable AS A COMPLETE UNIT. (Later units had a blade brake incorporated into the clutch, plus there were at least two manufacturers of the clutches.)
"Patio" means the tractor is painted white, and you had a choice of colors for the seat and hood.
The serial # range is known, and they are somewhat more valuable than the standard GREEN ones. The site linked below will tell you more.
Under the heading "Tractors", select "Custom Color Tractors", the last item on the drop-down menu.
