M.E.K
Jim in Ok
06-15-2007 14:20:13
I tried all the auto parts stores. Can anyone tell where i could find some MEK. I'm getting ready to red cote my tank. thanks
mlpankey
06-15-2007 14:35:33
 Re: M.E.K in reply to Jim in Ok, 06-15-2007 14:20:13
if mek stands for methyl ethal ketone .i picked some up at ace hardware . two days ago
F-I-T
06-15-2007 18:08:28
 Re: M.E.K in reply to mlpankey, 06-15-2007 14:35:33
...Ethyl
I just bought some at Lowe's the other day.
Jim in OK
06-15-2007 14:45:35
thanks alot I'll give them a try
msb
06-15-2007 20:40:45
 Re: M.E.K in reply to Jim in OK, 06-15-2007 14:45:35
BE VERY CAREFUL with that stuff. It is VERY rough on your innards(liver and kidneys etc.) if you absorb it through your skin(*and it happens quickly-wear the proper protective gear).One of those chemicals that probably should be restricted use.
dds-inc
06-15-2007 21:56:55
 Re: M.E.K in reply to msb, 06-15-2007 20:40:45
methyl ethyl is actually the ingredient for the cookers to make crystal meth!
Thats exactly what it does, first of all it makes you dumb as a cenemt block in sand, then it attacks your kids and liver.
F-I-T
06-16-2007 08:55:40
 Re: M.E.K in reply to dds-inc, 06-15-2007 21:56:55
Well, MEK is ONE of the ingredients, actually a solvent used to dilute and extract active ingredients along the process, along with Sodium Hydroxide (Lye), and phenylpropanolamine and some ephedrine from cough syrup. I just don't understand why a person who possesses the knowledge to brew up something that complex in a vacant house kitchen doesn't just get a real job in R&D at Monsanto or Dow and have a shot at a real life.
Nylon
06-16-2007 11:40:55
 Re: M.E.K in reply to F-I-T, 06-16-2007 08:55:40
Cause you cant really get those jobs anymore unless you have a phd. I have a BS in chem and geology. Not to mention probably pays alot more than a real job if you could keep from using your own product.
F-I-T
06-16-2007 19:15:42
 Re: M.E.K in reply to Nylon, 06-16-2007 11:40:55
It was meant facetiously.....
