flywheel cover for 1950 A
1951g
06-26-2007 08:29:05
Will a flywheel cover from a 60 fit a 1950 A?
1951g
06-29-2007 11:27:43
 Re: flywheel cover for 1950 A in reply to 1951g, 06-26-2007 08:29:05
Thanks for the replies.
Mike Aylward
06-27-2007 19:27:38
The starter cover for the 60 will fit your A just fine. It is when you try to put a 630 cover on that you would have to make a hole for the starter rod. The 60 and 620 have a timing inspection hole but otherwise they are the same cover. Mike
430WLPG
06-27-2007 16:39:46
yes and no, it will bolt right on, but there is no hole for the starter rod, if you make a hole for it it will work
