A with single front wheel
jlh
01-15-2000 19:03:04
We have a 1945 A with a single front wheel. I always thought the fork on the old 2 cylinders was non-removable. This tractor has a bolt on fork. It is not the same pattern as the newer tractors. Is this something that has been remodeled or did JD build some like this.
Toivo
01-16-2000 09:57:13
 Re: A with single front wheel in reply to jlh, 01-15-2000 19:03:04
If your AN is really a 1945, the fork should be nonremovable. If it has a split petestal so that the front end can be changed to wide or double narrow ect. it has a later petestal installed from a 1947 or newer A (serial # 584000& up)
jlh
01-25-2000 10:57:25
 Re: Re: A with single front wheel in reply to Toivo, 01-16-2000 09:57:13
We also have a 1951 A with roll-a-matic. It has a different hole pattern for the front wheel(s) to bolt to the pedistal. Did that style come out in 47?
Our 45 must have been modified.
Richard
01-15-2000 21:08:25
You have a JD model "AN" {N meaning narrow} tractor with a single front wheel. This is to prevent the front wheel from riding up on the sides of the irrigation furrows, as a narrow two wheel front end would do. It is made that way at the factory. Widely used in southern and SW US.
