build up hole vs. shaft
joelrand
07-17-2007 08:55:25
When rebuilding a 720D belt pulley/clutch, should I braze the operating sleeve hole or the fixed pin it rides on to take out slop? I don't have a press, so if I can do it without removing gear that would be best.
johns48jdb
07-17-2007 16:17:49
 Re: build up hole vs. shaft in reply to joelrand, 07-17-2007 08:55:25
if you weld on drill rod it will become real brittle. i don't know if you were planning on welded a head on it or not.
Mike M
07-17-2007 10:12:24
If it's bad enough to cause problems you usually need to do both. I make a new pin and then build the hole back. I think the pin is just 1/2" (or another common size) drill rod.
