JD A low speed 1st gear
Jeremys108
07-18-2007 11:29:21
What is the easiest way to tell if a JD A has the low speed 1st gear without driving it? It is a 1951 JD A straight 6speed. Is there a # cast into the transmission housing?
James Howell
07-19-2007 10:22:28
 Re: JD A low speed 1st gear in reply to Jeremys108, 07-18-2007 11:29:21
On my 52A the 1st gear is at the top right across from Reverse.
It is marked with a " 1 ".
HAPPY DEERE
07-19-2007 04:50:23
it has it automatically
CLW
07-18-2007 20:52:30
Jeremys108 said: (quoted from post at 11:29:21 07/18/07) What is the easiest way to tell if a JD A has the low speed 1st gear without driving it? It is a 1951 JD A straight 6speed. Is there a # cast into the transmission housing?
The creeper first gear started with serial number 648000. As Drew said, if it is the single stick transmission it will have the low speed first gear.
Drew
07-18-2007 12:02:36
If it is a straight 6, single stick transmission, then its a creeper gear tractor.
