Paint
37JD A
07-19-2007 10:57:32
I am in the process of sandblasting and preparing my 37 A for the paint job. What paint and primer do you restorers recommend. Is the paint found at John Deere Implement dealers any good, or should I go to a auto-body man and have him mix it for me. Any help would be appreciated! John
Hoss in Maine
07-20-2007 10:31:22
 Re: Paint in reply to 37JD A, 07-19-2007 10:57:32
Pat, You are so right about paying attention to mixing different paints and thinners etc.I must clarify,the paint I use I do get at a jd dealer but is oil based rustoleom. My dealer suggested it cause it was cheaper than the jd brand.He will also do his damndest to get a part I might need,nice guy.I painted my a with it and always get comments on shiney paint job.See ya later Hoss
P Browning
07-20-2007 11:24:12
 Re: Paint in reply to Hoss in Maine, 07-20-2007 10:31:22
I knew you must have had an angle there. It's Good news to get the rest of the story! (PatB)
Hoss in Maine
07-20-2007 06:05:19
Pardon me? Did I say it was syn paint? NOOOOO!The paint is oil base jd green.later Hoss
P Browning
07-20-2007 06:49:15
 Re: Paint in reply to Hoss in Maine, 07-20-2007 06:05:19
Hoss -- If you are buying Classic Green from John Deere, you are buying Synthetic Enamel made by Valspar for John Deere. In as much as it is not a latex or water-based paint, I suppose one may call it oil-based using the terms of decades back. But yes, it's SE or Synthetic Enamel. And I have experimented using mineral spirits as a reducer for SE, and believe me -- it was terrible. Fortunately, I covered only a couple pieces - then contacted Shawn Mahady at Valspar Engineering a number of years back, and with his help, I learned a bit about SE and what reducers to use plus data on hardeners -- those catlytic compounds that hasten the cure and bring out a deep (high) gloss. I do not say what you should or should not use with various paint products, but I DO recommend you experiment on some unimportant surfaces before shooting your prize tractor or implement. It won't take long to learn what you need to about paint additives.
I also urge folks new to spray painting of farm machinery to research health-related issues to be aware of when shooting paint and paint compounds. Thee are some evil chemicals out there!(PatB)
Hoss in Maine
07-20-2007 04:41:35
Im sorry guys, it aint linseed oil its mineral spirits.I use about 1part min oil to two parts paint.It sprays real nice and comes out nice and glossywith about 30lbs pressure. The other night when i wrote this the ole ladey wuz smoking that sh[4t and ithink i got a little secondhand smoke. later Hoss
P Browning
07-20-2007 05:36:57
 Re: Paint in reply to Hoss in Maine, 07-20-2007 04:41:35
Pardon me -- I have been taught that you should NEVER, EVER add Mineral Spirits to any Synthetic Enamel paint!!! How many years did it take to cure?
720 in pa
07-19-2007 12:29:09
i used utech automotive paint and am very happy with the results.it needs hardener mixed in before spraying.ive already heard if you use hardener with john deere paint it will get glossy just like automotive paint.
Hoss in Maine
07-19-2007 11:50:29
Hey there 37JDA, I dont know what the "pros" use but I use genuine jd paint avalible at the dealers and love it. I cut it with linseed oil and it comes out beautiful. later Hoss
Mike M
07-19-2007 12:28:40
 Re: Paint in reply to Hoss in Maine, 07-19-2007 11:50:29
Linseed oil ? boiled or raw ? do you use it to thin enough to spray it ?
