'41 h brakes
mike conde
01-18-2000 06:18:47
I have posted this message before and didn't get many responses. So I'll post it again:
I was wondering if it would be a hard job to fix the brakes on my '41 h. This would be done in my ag class. My father thinks it might just be the oil seals that are leaking oil. How hard would it be to change these. Many people have told me that i would have to pull the axle housing. is this phesibal for a group of ametuers. On the other hand or teacher is an expert
MikeH(Tx)
01-18-2000 09:39:10
 Re: '41 h brakes in reply to mike conde, 01-18-2000 06:18:47
Mike, it is not a hard job, but yes, you have to remove the axle housing to get to the brakes. I did it when I restored mine a few months ago.
It is a one man job, but is pretty heavy to move around. You have to support the tractor rear end under three places, the axle you are not working on, the middle, and the one you are working on.
Brake shoes will need to be drilled out and new ones installed with rivets. All straightforward. The only problem I had was that the new linings were too thick to fit back in the drums, probably caused by some corrosion I left on the drums. I should have turned them. When I re-installed, I broke the shoe lining and had to redo it. On the second one, I sanded the new lining down to 3/4 original size before refitting and it worked fine. Only problem was that it was probably asbestos (cancer causing in lungs) so I used a shop vac while sanding and used a respirator. Your school shop will probably not allow that activity indoors.
Seals were easy to replace and without incident.
RonMC
01-18-2000 07:25:28
Mike, I could scan the appropriate parts of the I&T so you could have a look. It also describes replacing the seal. Let me know, could do it later today if it will help.
mike conde
01-19-2000 07:19:37
 Re: Re: '41 h brakes in reply to RonMC, 01-18-2000 07:25:28
don't worry about that. I already have them!
