Unstyled BO
Jim James
08-09-2007 05:21:12
Can someone please post a reply on this board to give me a idea on what a older restored BO is worth that has the correct orchard hood but not sure about fenders. Was restored in late 70"s. Only ran in parades since then.
If possible, could post a correct picture as well. It is a 36 or 37 year tractor.
Gareth Mc
08-10-2007 20:18:28
 Re: Unstyled BO in reply to Jim James, 08-09-2007 05:21:12
The most important difference between the BO and the BR is that the BO always has turning brakes rather than the single foot brake on the floor platform. If it does not have turning brakes it is not a BO, even if it has the orchard type hood. Turning brakes are a real advantage when pulling an implement in the field and trying to turn at the headland. Once you have gotten used to turning brakes you will never want to do without them.
My prediction is that smaller vintage tractors like the BO will appreciate faster in value than larger tractors over the next, say twenty years. The next generation of collectors may find storage a problem as well as providing a large pickup truck to haul a trailer to shows. The phenomena of nearly everyone in the hobby owning a huge pickup has only developed in the last twenty years. With growing environmental concerns and heightened gasoline prices, that trend will almost certainly be reversed. Furthermore, Orchard tractors of every make draw more attention at shows because of their limited production numbers. A BO should be a better investment than a BR.
Further with the BR you really cannot alter the tractor beyond new fenders and hood. On the BO you could do an all-out restoration and add a lot of orchard tin, not all of which was provided on every tractor.
As was said beauty is in the eye of the beholder and sometimes the BO orchard tin can be a bit overpowering.
Best wishes in your decision, Gareth
Tx Jim
08-10-2007 05:01:58
 Re: Unstyled BO in reply to Thumb Farmer, 08-09-2007 05:21:12
Value of an antique tractor is in the eye of the beholder. I would guess between $5K and $7K. I've owned a '45 BO since the late 60's that $7K will not get it bought as it's not for sale. Tx Jim
Jim James
08-10-2007 08:12:28
 Re: Unstyled BO in reply to Tx Jim, 08-10-2007 05:01:58
I was guessing between 5,000.00 and 7500.00. I have known the tractor for years since it was restored, I mean built back up from 5 gallon buckets of parts and pieces after the owners brother had tore it down to attempt the restore and then left it in pieces. It still is on factory steel with lugs avail, but not installed as they bolted rubber tread to it to drive on pavement. Has been stored inside with the exception of one parade per year. The grandson of the org. owner just inherited it and does not look like he wants to keep it. I am hoping to get it bought. Can someone tell me what the difference is between the BO and BR????
Duane Larson
08-09-2007 08:11:27
Jim James,
Go to www.aumannauctions.com, hit "results", search on Deere BR and All Words - you'll see what they sold for at their auctions. With a little more careful searching you can get rid of the BR toys. There may be other auction sites which provide similar results but I don't know of them.
JBiff76
08-09-2007 07:42:06
Jim, I have noticed that some people on this board do not get alot of or any replies, myself included. Others will ask similar questions and get a whole page full. I don't understand. A question is a question.....Right? Anyway. I am by no means an expert on tractor value but here's my 2cents. Earlier BO's seem to be worth a little more than the later ones w/electric start. I bought a BR a year ago, 36 model, older restoration, good runner, but was on full steel and gave $6500.00 for it. It seems to me that the steel wheel BR/BO's bring more than rubber tire versions. If it is a good running, complete BO, I think you will have a hard time finding one for under 5k. As for a picture, check the archives. Type in John Deere BO or John Deere BR and see what comes up. Hope this helps. Jon B.
