36 L crank location
1951rtu
08-12-2007 07:04:45
Where does the crank go on a 36 L? Thanks.
Curt
1951rtu
08-12-2007 07:07:32
 Re: 36 L crank location in reply to 1951rtu, 08-12-2007 07:04:45
I meant to ask where does it go when not being used. Thanks
Dwayne
08-12-2007 14:26:01
 Re: 36 L crank location in reply to 1951rtu, 08-12-2007 07:07:32
the L was not built until 1938. If you have a 38 unstyled L there was a hilder on the side of the driveshaft cover. if you have a styled L there was really no place for it designed to go. I have some archives photos thea show it stuck inside the base and shield assembly on the mag side. Myself I will lay it between the steering post and the left fender, and let it rest on the foot plate. I wouldn't advise this on a restored tractor because it will scratch the paint. I would leave it in the truck.
Mike M
08-12-2007 15:31:54
 Re: 36 L crank location in reply to Dwayne, 08-12-2007 14:26:01
It might grow legs and walk off ! Locked in truck is the best.
