styled A not running right
jeremy in NE
08-12-2007 16:17:01
Took the carb off and cleaned as best we could for now and put back on to see if it would run. Got it running, but it sounds like it is pulling a 3 bottom plow in alfalfa just setting there running. The carb is going to be cleaned properly and rebuilt, but could that be the cause of it laboring so bad to run or is there another issue that needs addressed. Thanks
teddy52food
08-12-2007 20:15:50
 Re: styled A not running right in reply to jeremy in NE, 08-12-2007 16:17:01
Sounds like the timing is late. If it has a distributor the advance weights could be stuck.
