Flow control valve leak.
John R.
08-17-2007 17:59:43
I was using my 2030Gas model for bush hogging. All of a sudden the hydraulic fluid was shooting out from underneath the right side of the rear end. Determined it is squirting out from between the power steering flow control valve and the transmission housing. Does the ps flow control valve simply bolt on to the transmission housing? If I remove it will parts fall out? How shall I fix? get a new housing and all interior parts? HELP!
Roy Suomi
08-17-2007 19:50:32
 Re: Flow control valve leak. in reply to John R., 08-17-2007 17:59:43
Take the housing off and replace the all the o-rings on that surface..Try to use the oem o-rings..Some use a hard white or amber o-ring there ..I'm not sure if they're still available , but they're tough as a pine knot..Torque the bolts to 35 ft.lbs. Nothing will fall out ..You will loose some oil unless you drain it down...
John R.
08-18-2007 16:43:18
 Re: Flow control valve leak. in reply to Roy Suomi, 08-17-2007 19:50:32
Roy...thanks. You are right on...only thing is the dealer forgot to include one o ring. Would have been able to get it home from the field if I had it. Well so much for being upset. Will have to get it done on Monday. Was a nice walk though for a 1/2 mile back to the line fence.
