51' AR tranny....
JJ. in B.C.
08-19-2007 12:22:28
My 51' AR Ser.# 277217 was hung up in 2 gears. After removing top, found the front shifter shaft had come adrift. Removed flywheel along with a number of shims that had been inserted in the splinesthird party image, what looks like a large mangled locknut found in bottom of cover third party imageand a rivet thro the hub flush with the bottom of the splines that doesn't seem to be serving any purpose third party image. Removed the trans. side cover and found the remains of the cap screw, lock washer and shifter shaft adjust. screw ground up in the bottom of the cover allowing the shaft to slide out.
The good news is the dealer has parts on the way. My main question is, what position should the shifter gates be in when reassembling third party image
Thanx for any help, JJ.
