4020
Jim in OK
08-23-2007 14:25:27
I'm doing a little research for my uncle. He has a late 60's 4020 diesel with turbo. he is wanting to change the two six volt batteries setup for one 12v. can you get enough cranking amps in one 12V? has anyone had any luck doing this? Thanks
Will Herring
08-26-2007 08:06:05
 Re: 4020 in reply to Jim in OK, 08-23-2007 14:25:27
Good old custom inginuity.
JD9295
08-26-2007 06:42:38
you sure its got 6 volt batteries.
the 4020D is a 24 volt system with 2 (12) volt batteries that put 24v to the starter and run everything else on 12v split.
if it has 2 6v and not spinning up good, theres the problem
steve-jd4000
08-23-2007 21:15:07
yes you can do 12v battries, Get 2 that will go in the box and hook the + to + to starter and - to - to frame,
I did that in my 4000 it starts up good than two 6v.
R. John Johnson
08-23-2007 19:42:42
You mean like this?
third party image
It's a single 4D-XHD battery with 1000 CCAs. Both battery cables are 2/0 and are 24" long. Boy does she turn over now!.
John
zwr
08-23-2007 17:50:27
On my late 4020D, there's a single 12V "Big Rig" truck battery sitting ON the platform in front of the seat. Works fine if you can put up with less foot room.
mattd
08-23-2007 17:30:55
u should put 2 12 volt batteries in. just run both + cables to starter and - to frame
JD9295
08-26-2007 06:44:37
 Re: 4020 in reply to mattd, 08-23-2007 17:30:55
if the tractor still has the generator you dont want to do that.
4020's are pos ground
jd40an
08-23-2007 15:47:28
I did this with a 4620. Mounted a 1050 amp battery as close to the starter as possible, with cables only a foot or so long. works great--much better than the 2 6 volt batteries under the platform, with the necessary looooong cables for that setup.
