Average weight of Model 60
Jerry
01-23-2000 15:41:18
I plan on buying a JD Model 60 and need to know about how much it weighs before I decide to put it on my trailer or my friends. Anybody out there have any ideas. My trailer will handle about 4300 lbs and my friends about 7000. I hate to borrow things and would like to use my if the weigh is within limits.
Nathan(GA)
01-24-2000 18:58:05
 Re: Average weight of Model 60 in reply to Jerry , 01-23-2000 15:41:18
Jerry, 60 service manual says dry weight for narrow front 5300 and wide 5690. It would be considerably more with fluid in tires and extra weights. I definately would NOT put on 4000 lb. trailer. If the 7000 lb is the light angle iron type I wouldn't trust it either. Axles are usually rated lower than actual capacity but you have to consider tire condition and construction. I hauled my 620 about 150 miles on a solid steel trailer(heavy built), but no trailer brakes. The tractor and trailer were about 9000lb. I had enough power but could NOT stop very well. This was stupid on my part and I would NOT recommend it. I made it OK, but I was lucky. It would be better to pay someone with the right equipment to haul it for you than to have a 60 scattered all over the road and have to buy your friend another trailer. Just something to think about. Good Luck
Nathan
Robb
01-24-2000 15:40:27
I bought one about a year ago no power steering, narrow front end but had some water in the tires & it's weight was 6800lbs
MIKE
01-24-2000 01:31:43
book says it weighhs 5300
clooney
01-23-2000 16:02:56
Jerry, a typical 60 with tricycle ft end & no p/s or wide ft. end & no ballast in tires will go about 5700-5900 lbs. add about 300 lbs for wide ft, 200lbs apx. for p/s, 400lbs+ in each rear tire if full of ballast, It will be a handful on a 7000lb. trailer without sway control & equallizer. Don't even think of pulling it without trailer brakes. About 4000 on rear wheels with no ballast.
Joe
01-23-2000 15:49:08
I have a 60 that i have been pulling for three years. Dry with no weights it runs about 5500 to 6000lb
