4020 Cab- Permanent or Removable?
Placer
08-26-2007 17:07:26
I am looking a 4020 with a cab...however I do not want a cab. Is the cab on the 4020 a bolt on that is removeable or is it permanent? Thank you in advance.
low budget
08-27-2007 02:53:59
 Re: 4020 Cab- Permanent or Removable? in reply to Placer, 08-26-2007 17:07:26
Saw one once that the platform and "fenders" had been left and the rest torched off. It didn't look pretty.
Brent in WI
08-26-2007 18:29:51
Do your homework before buying as you will more than likely need some parts when you remove the cab like a platform, steps, possibly fenders and rockshaft covers to name a few. The cost of those parts alone can be priccy and should be considered when buying the tractor.
steve jd4000
08-26-2007 18:05:50
Yes it can be Removable,
msb
08-27-2007 12:33:20
 Re: 4020 Cab- Permanent or Removable? in reply to steve jd4000, 08-26-2007 18:05:50
Cab can be sold for more than the parts needed to put it back together will cost. What year tractor and which cab. There should be the manfacturer's tag on the inside somewhere.
