Want to fix a screw up on my brakes UNSTYLED A
amatwater
08-29-2007 11:16:42
I have a 36 jd a and the brake drums are welded and riveted incorrectly. Can some one point me in the right direction as far as putting this back correctly. I don' want to get into the drum but only take the precautions of attaching the drums correctly. and yes i realize the brakes shouldn't be welded.
thanks
ama
Mike M
08-29-2007 11:30:24
 Re: Want to fix a screw up on my brakes UNSTYLED A in reply to amatwater, 08-29-2007 11:16:42
You may just want to find another set. Check the parts books and see if they happen to also fit newer A models. If they do then it should be easy to find some.
Every once in awhile you see one with oversized rivets or bolts holding on the drum because the originals started to work loose from some hard brakeing.
