My 825 Two-Way Plow.....is Finished
Rich-WI
08-30-2007 12:01:36
Took the plow apart and sandblasted and painted each part before assembly....turned out real nice....I don't think it will see dirt while I own it.Thanks for looking, Rich a.k.a (LittleD)
P.S. Now I can say My JD 520 pulls 4-16'S in any soil..he he
third party image
third party image
third party image
third party image
third party image
third party image
Tyler-MO
09-04-2007 08:26:59
 Re: My 825 Two-Way Plow.....is Finished in reply to Rich-WI, 08-30-2007 12:01:36
VERY VERY NICE!!!! I HAVE A 3x16" 825 ROLL-OVER BEHIND MY 720 DIESEL AND IT'S VERY IMPRESSIVE. I JUST HAVE TO GET ALL OF THE COULTERS MOUNTED AND IT WILL BE MECHANICALLY COMPLETE. I ALWAYS WANTED A 2 BTM ROLLOVER FOR MY 520lp BUT NEVER FOUND IT BEFORE I SOLD THE TRACTOR. THEN I GOT THE 720D AND PLOW BOUGHT WITHIN 60 MILES OF ONEANOTHER IN COLORADO AND HAD TO BUY THEM.
IF YOU WERE TO USE THE PLOW I KNOW THAT YOU WOULD LIKE IT!!
MY SUGGESTION IS TO TAKE A NICE PHOTO OF THE TRACTOR NEAR A FIELD (AWAY FROM YOUR CONCRETE DRIVE) AND SEND IT IN TO GREEN MAGAZINE.
TYLER IN MO (NOW IL)
LittleD
09-05-2007 17:13:32
 Re: My 825 Two-Way Plow.....is Finished in reply to Tyler-MO, 09-04-2007 08:26:59
Tyler,
Great looking set up..... a lot of iron hanging off the back. I'll bet with the wide front and 5 piece weight set the front stays put pretty good.
P.S. hoping to get some photos to GM....
thanks for the suggustion, Rich
Tyler-MO
09-04-2007 08:29:48
third party image
HERE IS MY TRACTOR AND PLOW(AT LEAST A LINK TO IT)
wilamayb
08-30-2007 21:08:40
Looks good!!!!
I have a 825 3-16 that I sometimes put behind my 720D standard. I hope at some point I get the time to devote to cleaning it up a little bit. I'm not sure I'm ready to give up the playing as you have by taking a vow not to plow with it.
Rich-WI
08-30-2007 21:34:13
 Re: My 825 Two-Way Plow.....is Finished in reply to wilamayb, 08-30-2007 21:08:40
wilamayb,
This is the set up I use when I play in the dirt.
Sure wouldn't mind having a 720D with 3-point.
Have a great weekend, Rich
third party image
Ebbsspeed
08-30-2007 14:22:36
Does a rollover plow have to be manually flipped or is there some "automatic" way for it to turn.
LittleD
08-30-2007 14:35:48
 Re: My 825 Two-Way Plow.....is Finished in reply to Ebbsspeed, 08-30-2007 14:22:36
Ebbsspeed said: (quoted from post at 14:22:36 08/30/07) Does a rollover plow have to be manually flipped or is there some "automatic" way for it to turn.
Ebbsspeed,
The rollover is done with hydraulics, the plow has the same motor unit that is used in the front of the tractor for the power steering.
Thanks Rich-WI ( a.k.a ) LittleD
KIP in MX
08-30-2007 12:54:26
Looks better than new! We pulled a 3-bottom like that for years behind a 4010D on our farm in the Pecos Valley (NM). It was about all that tractor wanted. Anyway, nice job on the tractor and plow!
Kemper
08-30-2007 12:17:22
Very Very nice! i'd sure like to have a set of front weights.
Mike M
08-30-2007 12:08:23
Very nice !!! Never ever saw anything like it.
