Help with JD 140 Garden tractor
John Mason, Mic
09-06-2007 17:45:33
Hello all, Sorry this is not about a JD farm tractor but....
This is a 1970 140. Won't start. Got spark, gas getting into the carb but seems the spark plug stays dry.When I took off the carb to give that a once over I turned the motor over and the valve was functioning. Got good suction at the carb. Usually I can figure these old units out but this one has me puzzled. Can anyone help me or direct me to a forum for garden tractors? I get a great deal of help here regarding my 1955 fergie and my 2N before I sold it. Thanks in advance. Sincerely, John Mason
Roger in Iowa
09-06-2007 19:52:42
 Re: Help with JD 140 Garden tractor in reply to John Mason, Michigan, 09-06-2007 17:45:33
Put a little gas down the spark plug hole and see if it will start.
Roger in Iowa
Bob
09-06-2007 19:24:39
If you have gas in the float bowl, and the mainjet isn't clogged, and you have spark, it SHOULD start!
Have you tried a different spark plug?
Only other thing would be valve settings, and if tthe valves are seating properly.
JDD
09-06-2007 17:57:19
www.weekendfreedommachines.com
