2010 john deere
jenn
09-09-2007 19:21:48
What engine will fit in a 2010 industrial John Deere tractor or a 2010 Utility tractor?
jdemaris
09-10-2007 06:17:11
 Re: 2010 john deere in reply to jenn, 09-09-2007 19:21:48
2010 uses the same engine-mounting pattern and footprint as any 1010 engine as also some gas combine and power unit engines - model 45 I think? But, most 1010 engines are less cubic inches. I've seen many 1010 tractors with 2010 engines - but not sure I'd want to go the other direction with less power. 1010 gas is the same size as a 420 two-cylinder, but has four small pistons instead of two big ones. 1010 and 2010 also use the same engine-mount pattern as the 420s - but obviously a 420-430 engine is shorter.
420 two-cylinder is 113 cubic inches
1010 gas is 115 cubic inches
1010 diesel is 144 cubic inches
2010 gas is also 144 cubic inches
2010 diesel is 165 cubic inches
