What am I missing?
bunghammer
09-19-2007 17:57:48
I was taking my 60 out for a drive when it started back firing and then, boom it back fired really loud and quit. I pulled back to my garage and loked it over. The ignition timing was ok, but it would compression lock when I turned it over. So I checked the valve timing. At LHEO the exhaust valve was closed but the intake was open. I then checked cam bearings and cam gear bolts all were good, cam to crank timing was also good. What else would have caused the timing to change? What am I forgetting to check?
bunghammer
09-21-2007 19:58:57
 Re: What am I missing? in reply to bunghammer, 09-19-2007 17:57:48
Yep, I got it running yesterday. The keyway on the rotor was sheared off. I don't know why I didn't see that before. I also noticed my coil gets really hot and is leakin' oil out. Mabey this had somthing to do with it, who knows.
teddy52food
09-21-2007 19:27:53
Did you get it running yet? What did you find?
MLD
09-20-2007 08:49:23
Our B started missing & backfiring one day, the rotor button had caught the condenser wire in the distributor & almost cut it in two. I'd check in there before I'd start pulling ther engine apart, might get lucky??
RobMD
09-19-2007 18:03:26
hmmm... pull the valve cover off and see what happened in there. I'm thinking you broke a rocker arm.
