JD 2010 Stuck PTO Lever
JeffCF
09-20-2007 17:34:32
I have a 1962 JD 2010 (gas) tractor. Today, after mowing a few acres (Woods finishing mower 540 rpm), I refueled and restarted the tractor. When engaging the PTO lever, the lever moved forward, but the PTO didn't engage (stub shaft connected to mower didn't rotate), and now the lever won't return to the disengaged position. I removed the mower and can turn the stub shaft freely by hand. I'm afraid I'll be removing the rockshaft housing and PTO clutch assembly, but I'm hoping there is an easier fix. Can anyone help? Thanks in advance.
Mike M
09-21-2007 05:31:07
 Re: JD 2010 Stuck PTO Lever in reply to JeffCF, 09-20-2007 17:34:32
Just follow the book and it isn't too bad to do. Glad I had borrowed a book for the one I fixed. It gave the location of a few hidden bolts,under anoter plate or something ? to remove as to get the rockshaft assy. off. I used a sprial roll pin too in place of the regular kind. they aren't very big.
Bob
09-21-2007 06:14:43
 Re: JD 2010 Stuck PTO Lever in reply to Mike M, 09-21-2007 05:31:07
There's two 3/8" bolts at the rear right, inside the "hole" that's opened up when you remove the seat support. If you lift the left cover WITHOUT removing the 2 hidden bolts, the internal hydraulic supply tube will be "killed". I repaired one for a "do-it-yourselfer" who mangled the tube, so make sure to find and remove those two capscrews.
JeffCF
09-20-2007 19:01:45
Thanks for the reply. I was hoping for a quick (and easy!) repair, but appear to be out of luck. I've got my shop manual and tools ready to go - looks like I know what I'm doing the next few days :(
RobMD
09-20-2007 19:29:25
 Re: JD 2010 Stuck PTO Lever in reply to JeffCF, 09-20-2007 19:01:45
I just thought of something... I wonder if you can use anything stronger than the roll-pin. Maybe loctite a cut off grade 8 bolt in the place of the roll pin.
Bob
09-20-2007 20:04:50
 Re: JD 2010 Stuck PTO Lever in reply to RobMD, 09-20-2007 19:29:25
Use a Spirol pin or drive a smaller roll-pin inside the first roll pin. Then, finish with a piece of stiff wire inserted through the little pin, and wrapped around the lever end/shaft, and secured with a twist.
RobMD
09-20-2007 18:26:28
common problem... a roll pin sheared in the linkage down near the shaft, you got to pull the whole rockshaft and all off... not fun at all.
