John Deere 5010 won't move
John Ritchie
09-23-2007 09:18:15
Just got JD 5010, starts good but cannot engage the tranmission in any gear. Any suggestions on cause and repair?
onefarmer
09-24-2007 14:23:58
 Re: John Deere 5010 won't move in reply to John Ritchie, 09-23-2007 09:18:15
Do 5010's have a rearend disconnect like a 4020? On a 4020 by your left foot there is a lever that disconnects the rear for towing. At least there is on a power shift model.
John Ritchie
09-23-2007 18:02:53
Yes the clutch pedals moves to the floor, the gear shifter moves with some force thru the gears but will not lock in a gear. The tractor has sat since Sept 2006.
5020s rock
09-23-2007 12:21:14
hi--does the shift lever move? does the clutch
pedal move? can you get the to "lock" into a gear? 5020s collect dirt under the dash where the rods go into the trans and you CANNOT shift them.
also, the pivot bearings in the bell housing like to rust up to the point the pedal will not move.
Bob
09-23-2007 09:41:41
Your post is ambiguous.
Is the clutch sticking, so it doesn't disengage, to allow you to shift the transmission, or WHAT???
