1944B Only Runs on Choke
1944B
09-29-2007 12:52:26
My 1944 B started for the first time today (it has been a long road), but it doesn't want to run with the choke off. It doesn't seem to want to throttle down and runs rough when the throttle is increased. The carb is a DLTX24 (not right for the tractor, but have heard it should work) and was "cleaned" by others before I bought the tractor - wondering if it might have the passageways blocked. What should I try to get it to run better? Thank you!
P Browning
09-29-2007 16:13:09
 Re: 1944B Only Runs on Choke in reply to 1944B, 09-29-2007 12:52:26
Yes, you have a blocked IDLE passageway. Two things here, the model of carburetor you have and the trouble the carburetor has. You can learn more about both issues at the JD-H Restoration Site (below). Once at the site, under the heading ARTICLES 1, one-click on the drop-down that reads CARBURETORS. This is a 9-page piece on JD natural draft single barrel DLTX models of carburetors. There's theory and troubleshooting, and on page nine is a two part, no-wrench test you can perform on your carb to individually verify openness (or the lack of it) of the passage ways for IDLE and for LOAD.
Returning to the website mentioned, and under ARTICLES 1, one-click on the drop-down CARB ID CHART. There you will be able to identify the model of carburetor your tractor left the factory with.
Judging from what you have reported, I would venture to say you have a segment or two in the IDLE path that is blocked. The usual methods of "boiling" the carburetor clean with solvent will not work on 60+ year old cast iron carburetors -- why? The passageways become closed due to rust, and the solvents will not remove rust. The "community" generally uses what is known as aircraft drill bits -- long bits and you must use the precise size for your carburetor! Oversize any of the orifices and you have permanently altered the carb and its usefullness could be terminated!
What is a man to do? There is a reputable outfit known as Robert's Carb Repair, and they will counsel with you, sell you the RIGHT sized drill bits, and also sell you a video on overhauling your carb -- something along this line is a must if this is your first JD carb and you intend to do the work yourself. You can learn more at their website (www)(dot)(robertscarbrepair)(dot)(com). (PatB)
1944B
09-30-2007 07:21:44
 Re: 1944B Only Runs on Choke in reply to P Browning, 09-29-2007 16:13:09
Pat - thank you for the response. I was actually using your website and what I could see from previous responses before/during/after asking the question. I have ordered the drill bits, but in the mean time disassembled the entire carb to find quite a bit of paint on the inside coming loose. I cleaned this off and blasted each of the passageways with carb cleaner, pulled the nozzle and cleaned it and where it seats. Reinstalled and the tractor runs well at high and low throttle and all points in between. Thank you again...
