4055 dash display
jimscotland
09-29-2007 13:07:16
Got a 4055 and the display is set to kph. Is it an easy job to change to mph?
Sam from WA
10-01-2007 19:50:23
 Re: 4055 dash display in reply to jimscotland, 09-29-2007 13:07:16
you have to take the tach out of the dash and there are several switches on the back that must be changed. also make sure that the tire size is set right while you have it apart.
Sam from WA
09-29-2007 13:56:45
should be pretty easy, i"ve changed the displays on our 4450, 4960, and 8400 with no problems. none of them are here right now, so i can"t tell you how to do it, but it is pretty easy if you follow the instructions in the operators manual.
