John Deere 410C Shudder?
Jessie C
10-08-2007 05:04:16
I have had this since new. In the past year it has developed a "shudder" when raising or lowering the bucket and a little with the backhoe. Last month I blew out the pump. I replaced with a rebuilt unit (must have gold in it for what it cost). When I fired up everything worked and worked well but within an hour or actual use the shudder has returned. Any ideas? I have a large farm and use this all the time. I am concerned the shudder problem led to the first pump failure, I do not want to replace another one.
jessie c
10-13-2007 06:15:42
 Re: John Deere 410C Shudder? in reply to Jessie C, 10-08-2007 05:04:16
I have looked at this a second time and still don"t see how this screen could comeout without removal of the whole tranny. Any suggestions guys? THanks in advance,
Jessie
Jessie C
10-08-2007 08:52:13
Thank you very much I will try and post results.
720 in pa
10-08-2007 08:20:38
take the suction screen out and clean it.follow the big suction line back to the transmission,take the elbow out of trans case,screen is behind there.most likely the shudder caused your fist pump to go out as a shudder normally indicates oil starvation.good luck
Jessie C
10-18-2007 04:32:38
 Re: John Deere 410C Shudder? in reply to 720 in pa, 10-08-2007 08:20:38
Any help guys? I still have not been able to get screen out...
Jessie C
10-10-2007 08:06:43
O.K. remove the suction line and found the screen. It is plastic and screen correct? Seems to be a tube. The problem is that it seems to be 8 or 10 inches long but I only have 6" of clearance before it hits the frame of the backhoe... Any suggestions? The part of it that I can see does not seem to be clogged or anything either.
Jessie C
10-08-2007 05:35:25
I forgot to say it but yes I replaced filter and all oil in system. ***Note*** I went with an off brand oil instead of hyguard this time but the cans said "can be used in place of hyguard" Thanks in advance for all of your suggestions by the way,
Jessie
