JD-1010 Diesel leaking hydraulic fluid into transm
John P. Martine
10-12-2003 14:33:50
I'm trying to help an elderly tractor owner and good friend with a problem, his 1010 Diesel leaks hydraulic fluid from his power lift system into his transmission. He tells me that his transmission over fills, thinning out his transmission oil. (I might be wrong about this, but he mentioned he used 90-weight transmission oil.) Please shower me with any and all thoughts on the subject. I did a search on the JD Discussion Board, found 1318 postings about the 1010, but nothing that seemed to relate to his unique situation.--JPM
Wayne in Pa
10-12-2003 15:00:36
 Re: JD-1010 Diesel leaking hydraulic fluid into tr in reply to John P. Martine, 10-12-2003 14:33:50
I may be wrong, but I think the only way hyd. oil can get into the transmission is at the Hyd. pump seal. Hope this helps.
Wayne
