JD 350-B Wont Idle Smooth
Jeremy
01-27-2000 06:16:30
I have a John Deere 350-B dozer that will not idle smooth, it really sounds like it is missing. All the way from an idle to full throtle it cuts out. The thing is, when you put it under a load, it sounds just fine. I found a piece of what looked like a hard rubber gasket on the return line from the injectors. The valve clearness is good, and I have put new injectors & filters in. I have also blown out all of the lines. I have run out of things to check, could you give me some more ideas!!!
FRED
01-27-2000 19:07:55
 Re: JD 350-B Wont Idle Smooth in reply to Jeremy, 01-27-2000 06:16:30
get the injector pump rebuilt.. it is coming apart inside.
